FPGA /CPLD NAND GATE
A project log for Rosetta stone of hardware programming
Using Hardware and software to create the programming building blocks.
FourthLevelMfgFourthLevelMfg 02/15/2017 at 23:460 Comments
this is programming for a CPLD / FPGA the programming is the same but the pin planner is different
A field-programmable gate array (FPGA) is an integrated circuit designed to be configured by a customer or a designer after manufacturing – hence "field-programmable".
A complex programmable logic device (CPLD) is a programmable logic device with complexity between that of PALs and FPGAs, and architectural features of both.
Schematic Version
VHDL version
Verilog version
uploads the code to the CPLD/FPGA
