Introduction
Robotics SDK allows to select the Intel-designed modules along with third-party component. It is compatible with a wide range of x86 hardware, LiDAR sensors, 3D cameras.
You might be even interested to run Robotics SDK on the real robot, I think my Mikrik open-source robot project could be a potential solution. It is a cheap, and easy to reproduce robot.
Mikrik Robot Source Project
I took my original Hackster tutorial called Mikrik, and replaced the original x86 board with UP7000 board based on N100 CPU
Setup is 100% similar to the Hackster tutorial, but the software part of the robot is integrated more deeply into a Robotics SDK.
I've built new Mikrik robot version powered by a UP7000 single-board computer (SBC).
