VESA compatible keyboard wall mount
I ran out of space on my desk for keyboards so I'm mounting them on my wall
This is a project for a wall mounted keyboard holder. It's designed in OpenSCAD, printable on any printer with a 200mm square build volume, and is currently holding an IBM Model M on my wall.
Why am I doing this? Because I have too many keyboards, and I have wall space.
The mounting holes for this thing are on the corners of a 100mm square, so this keyboard mount is VESA compatable.
scad - 1.51 kB - 02/06/2017 at 19:05
Download
  • 1 × 3D printer filament
  • OpenSCAD code
    Benchoff02/06/2017 at 19:04 0 comments
    Want to make your own? Here's the code:
    module arm(){
        rotate([-45,0,0]){
            cube([20,150,10]);
            translate([0,150,0])
                cube([20,10,97]);
            translate([0,153,90])
                rotate([45,0,0])
                    cube([20,10,30]);
    module vesa(){
        translate([0,0,0])
            cylinder(d=4.5, h=10);
        translate([100,0,0])
        translate([0,100,0])
        translate([100,100,0])
    module mount(){
    rotate([45,0,0])
    union(){
        arm();
        translate([150,0,0])
            arm();
        translate([0,0,0])
            rotate([-45,0,0])
                difference(){
                    cube([150,120,5]);
                    translate([35,10,0])
                        vesa();
    module brace(){
        union(){
            difference(){
            cube([13,75,22], center=true);
            translate([0,0,1.2])
                cube([10.3,102,20], center=true);
            translate([5,40,2.3])
                cube([20,20,22], center=true);
            translate([0,-55,0])
                cube([30,30,30],center=true);
            translate([15.2,29,0])
            cube([20,2,22], center=true);
    mount();
    rotate([0,0,-90])
    translate([-150,110,11])
    brace();
    rotate([0,0,90])
    translate([130,-90,11])
    brace();
View project log
