Log Entry #10 - February 6th, 2017
A project log for DIY Phone Controlled BB-8 Droid
In this project I will be making a BB-8 robot from Star Wars that is controlled by your Android smartphone. BB-8 can move and talk!
BrandonBrandon 02/07/2017 at 02:200 Comments
Today I finished Carving out the head. I didn't do a very good job though because the bottom was really bumpy, so I decided to fill the bumpy part with glue and then put a piece of paper on top and let it dry, but for some reason there was a leak and a bunch of glue spilled out, so I'm going to check it either later tonight or tomorrow. Also, it turns out I accidentally made a hole all the way through the head, so i'll have to patch that up with some wood filler later.
Update:
Here are some pictures
