Started Routing Rev E.
A project log for Pico Pal GBC
Microcontroller based PCB fitted into a gameboy color shell to run a gameboy emulator
peter-khoulyPeter Khouly 05/02/2025 at 15:290 Comments
Made some recent schematic updates to the new revision. Highlights include cleaner audio output, improved power efficiency, and support for an IMU to enable tap and double-tap gesture control. I'm also planning to implement automatic sleep and wake just like a phone.
Started routing again yesterday and aiming to finish up this revision soon.
Check out the blog for more.
https://picopalgbc.wordpress.com/
