I was fed up with my circa 2018 Aldi multimeter's backlight turning off after 15 seconds. I can't get anything done in 15 seconds. So! Let's hack the multimeter.
Opening it up was easy enough, remove the outer bumper, undo 2 screws, take off the backplate/pop-out stand, undo 1 more screw and we're inside.
Finding the backlight was easy, it was labelled "BL", with 2 wires disappearing under the board. Probing it showed it was drawing 2.8V, which seemed reasonable considering the battery was at 8V. I desoldered the red +ve wire from the board and extended the wire in exactly the same way everybody does but says not to.
IC3 turned out to be a handily located voltage regulator outputting 2.8V.
Grabbing the nearest SPST switch I had I found a space where it could fit and drilled a hole with a drill press, which amazingly, was spot on first try. That never happens.
To make up for my competence with the drill, I used a circular punch to put a hole through the rubber bumper, and that was almost exactly right. I should have left it alone, instead I punched another hole that wasn't my best work.
Anyway, viola! It's now a multimeter with a switch to turn the backlight on and off! No more 15 second timeout.
WARNING! DO NOT MODIFY YOUR MULTIMETER IF IT COULD BE USED WITH MAINS VOLTAGE.
Jared Young
Annelle Rigsby
Tom
Other than using too large a gauge wire, nice workaround.
