Don't buy crap power supplies!
A project log for Motion activated RGB-LED-Strip
LED-Strip activated by a PIR-sensor or button, only turns on if the ambient is dark enough.
jeremiasJeremias 03/21/2017 at 19:130 Comments
I changed my 12V Supply to a higher quality one, now everything works as expected.
I think the problem was, in sleep mode the circuit draws so little current, that the supply can't hold a steady voltage.
The only small problem left is, at low brightness you can see the individual brightness levels.
In the future I may add 10/12? bit software-PWM to get smoother dimming of the LEDs.
