Power supply issue?
A project log for Motion activated RGB-LED-Strip
LED-Strip activated by a PIR-sensor or button, only turns on if the ambient is dark enough.
jeremiasJeremias 02/07/2017 at 18:560 Comments
Everything works as expected if I power the circuit via the ISP programmer (Arduino UNO) or my bench power supply.
But if I use the 3,3V regulator from the PIR-module, the circuit behaves strange. I also tried a L78L33AC regulator powered from the 12V rail, resulting in the same strange behaviour.
My circuit consumes less than 10mA, which both regulators should be capable of.
