Right and Wrong Shift Key
02/08/2017 at 07:08 • 0 commentsOK, I have to set the screen saver to come on in the minimum time, one minute.
Now I have to wait a whole minute to see if it works.
Sending Right Shift key works! The screen saver stops!
But what the hell... "Stick-keys"?!? In Windows pressing shift 5 times asks to turn on sticky keys. :( Is it because the come too fast? No, any 5 in a row will do it, even separated by 10 seconds.
Today I thought of the solution! Alternate right and left shift! This fools Windows and no sticky keys dialog!
Connector for PIR
02/08/2017 at 07:02 • 0 commentsI chopped up a SCSI cable I found in the ewaste to make the connector. I pulled out the surrounding pins and cut the plastic with wire cutters. My soldering sucks :(
I'm so glad about standard 0.1" pins!
PIR Pins
02/08/2017 at 06:19 • 0 commentsI ordered the PIR sensors from Amazon, and this is what I got:There are no markings on the silk screen! What are the pinouts??
Google finds a few similar
but finally this one:Looks the same!
