DIY Gamebuino with a neat PCB
A DIY Gamebuino with a THT only PCB that allows easy soldering. The main focus of the project was to make it small and easy to make.
There are a number of game consoles based on the arduino platform. One of them is the Gamebuino. It's main advantage is the possibility to load programs from a micro SD card. This allows to play different games without having to re-flash the device each time. Most DIY Gamebuinos don't have support for the SD card in order to simplify the building process. Also, the Makerbuino DIY kits are expensive and discontinued. This version was designed to be closer to the size of the original while being cheap and easy to build.
Here's a demo video:
gamebuino_pcb_v01.fzz
Fritzing file
fzz - 127.37 kB - 09/03/2024 at 16:57
Download
The project's schematics.
Portable Network Graphics (PNG) - 45.39 kB - 09/03/2024 at 16:57
Preview
View all instructions
