3d printed housing/enclosure
08/04/2025 at 19:20 • 0 commentsDesigned the housing
It needs some improvements, but overall it turned out pretty ok
New base-board and power supply PCBs, Egg game
07/27/2025 at 02:21 • 0 commentsI assembled the new base-board featuring the new LED matrix. As the previous one, it also has 4 buttons and a speaker.
Made a silly mistake in the schematics, so had to bodge the LED matrix driver chip a little. Oh well...
Also assembled the power-supply board, it has a tiny 90mAh Li-Ion battery on it, a boost converter and a charging controller which is connected to a power-only USB-C port.
The boards have the exact same dimensions and intended to be on top of each other inside a housing, which I'm going to design and print next. Both assembled boards seem to work fine.
In the meantime, I coded a new game - essentially a clone of the Nintendo Game & Watch Egg game.
Switching to a custom-made LED matrix
07/18/2025 at 13:21 • 0 commentsI decided to experiment with my own custom-made LED matrix display, since the GPD340 display is basically pure high-grade unobtanium, and 10x7 resolution is very limiting for gaming capabilities.
So I designed a 15x10 matrix out of 0201 LEDs:
The resulting dimensions of the display area is 15 by 10mm with diagonal of ~0.7''.
I tried SMT-assembly service from one of the very well known PCB manufacturers for the first time ever, and gotta say the result totally exceeded my expectations:
No defects whatsoever, every single LED on every matrix I received works.
To drive the matrix I chose the IS31FL3743A LED driver which is controlled through I2C bus and is 5V tolerant. I also designed a breadboard- friendly module for experimenting purposes. The module features both the driver and the matrix with just power and I2C pins being exposed.
I evaluated this module (if it even works as intended) using a Raspberry Pi Pico.
Of course, made an obligatory BadApple demo:
After I played enough with it on Pico, I hooked it up to my original ATiny10-EMES proto-breadboard and started rewriting previous games/demos for the new display.
So far, I have Pong and Snake and almost completed Tetris-like:
Next up is to assemble a new main PCB with integrated LED matrix and its driver.
Snake game
09/12/2024 at 17:50 • 0 commentsA playable Snake-game has been implemented. Short playthrough:
Michael
