Parts required:
Adafruit 5×5 NeoPixel Grid BFF Add-On for QT Py and Xiao
Adafruit QT Py – SAMD21 Dev Board with STEMMA QT
Piezo Buzzer
Micro Switch w/Lever
Header pins and a bit of wire
Optional: Right angle USB-C cable
Pins used:
The micro switch – ‘NO’ or Normally Open pin is on A1
The Piezo is on pin A2 which requires PWM
The 5×5 matrix uses pin A3 by default
All share ground
More information available at
https://www.somenice.com/2023/01/the-micro-one-armed-bandit/
Andrew Smith
Thank you
