In this project, you will learn how to do basic electrical automation and control via the web. Think of the NEST.... only more open and hackable! Using Websockets, Javascipt and HTML5, you will have a simple way of viewing remote data and be able to control some solid state relays. This framework will allow you to create more complex IoT applications. The example will combine a FRDM-K64F and a FRDM-AUTO to read a temperature sensor and control a solid state relay.
Everything is open, hackable and extensible!
Here is the main page with instruction videos, links to schematics, etc.
https://community.freescale.com/docs/DOC-101449
