Features
Detailed Description
PD Stepper revolutionizes stepper motor control by integrating USB-C Power Delivery, an ESP32 microcontroller, and an A4988 stepper driver into a single, compact PCBA. This unique combination allows for dynamic voltage adjustment up to 20V, providing the flexibility needed for a wide range of stepper motor applications.
Integrated A4988 Stepper Driver
The onboard A4988 stepper driver eliminates the need for external driver modules. This integration reduces complexity, improves reliability, and makes PD Stepper a true all-in-one solution for stepper motor control.
Variable Voltage Control
PD Stepper's USB-C PD capability allows for on-the-fly voltage adjustments up to 20V. This feature optimizes your stepper motor's performance across various scenarios, all managed through the USB-C PD protocol.
ESP Stepper Motor Server Integration
The onboard ESP32 microcontroller opens up a world of possibilities. Take advantage of its processing power, wireless capabilities, and extensive library support to create sophisticated control systems. The PD Stepper comes pre-loaded with the ESP Stepper Motor Server, turning it into a standalone stepper motor control server. This powerful software allows for easy configuration and control of one or more stepper motors via a web interface, without the need for additional coding. Whether you need wireless control, integration with other sensors, or complex motion algorithms, the ESP32 and ESP Stepper Motor Server combination has you covered.
Easy Connectivity
With built-in spring terminals for 4-wire stepper motor connections, PD Stepper makes it simple to set up and swap out motors as needed. This design choice enhances the board's versatility and user-friendliness.
Technical Specifications
Applications
Open Source
PD Stepper is built on open-source principles. We encourage users to explore, modify, and improve upon our design. The firmware is compatible with popular ESP32 stepper motor libraries, allowing for easy customization and expansion of functionality.
About elektroThing
PD Stepper is proudly part of the elektroThing ecosystem. At elektroThing, we're committed to creating innovative, open-source tools that empower makers, engineers, and hobbyists to bring their ideas to life.
FAQs
Q: What makes PD Stepper different from other stepper motor controllers?
A: PD Stepper integrates USB-C Power Delivery, an ESP32, and an A4988 stepper driver into a single PCBA, offering a compact, all-in-one solution with wireless capabilities and flexible voltage control.
Q: Do I need any additional components to use PD Stepper with my stepper motor?
A: No, PD Stepper is an all-in-one solution. Just connect your stepper motor to the spring terminals, power the board via USB-C PD, and you're ready to go.
Q: Is programming experience required to use PD Stepper?
A: While PD Stepper can be used with default settings, its open-source nature allows for extensive customization if you have programming experience. We provide examples and documentation to help users of all levels.
For more information, visit our website or contact us at hello@elektrothing.com.
