Use thin carbon fibre sheet as canopy/envelope - make it more like a microlight
A project log for Mona Lisa ParaFoil
A lightweight compact fabric/stiffer material Parafoil underslung is a raspberry pi for control and camera feed. See notes this has evolved
slncioSlncio 02/10/2017 at 09:500 Comments
Use thin carbon fibre sheet as canopy/envelope - make it more like a microlight with good thrust to weight ration, forward mounted mid or top of wing motors/props to take advantage of coanda effect and try to protect the prop blades. Improvements here would be lower weight and more manoeuvrable wing/canopy.
Examples: https://carbonflyer.myshopify.com/
Reading: https://en.wikipedia.org/wiki/Coandă_effect
