While soldering(especially with SMD components), I like soldering small components first and then bigger ones. I started with the Resistors and LEDs, and then the pushbutton, and then the battery holders.
While I did;t really need one, using a microscope to solder the SMD LEDs was helpful.
Sanjit Sarda
