🎯 Features
Hardware Features:
  • ATmega32u4 Microcontroller: The brain of the device, capable of simulating a USB keyboard.
  • SD Card Support: Store and load scripts from an SD card for flexibility in payload execution.
  • AM1117 3.3V Voltage Regulator: Ensures stable power supply to the components.
  • LED Indicators: Provide visual feedback on different device states like script execution, SD card errors, or script loading.
  • SMD Components: Space-saving surface-mount components make the EvilDuck compact and ideal for DIY PCB design.
  • Male USB A Connector: Ensures easy plug-and-play usage with any computer system.
Software Features:
  • Predefined Commands: EvilDuck supports a variety of keystroke commands such as STRING, DELAY, CTRL, ALT, and many more.
  • Flexible Script Loading: EvilDuck can load scripts from an SD card, making it easy to swap payloads on the go.
  • LED Feedback: Customizable LED feedback based on script execution status, SD card presence, and other error conditions.
  • Easy-to-Write Scripts: EvilDuck uses simple commands to write powerful scripts that can execute keystroke-based payloads.
🎯 Core Functions
EvilDuck’s core functions revolve around simulating a USB keyboard and sending keystrokes to the target machine in rapid succession. The primary operations include:
  • Keystroke Injection: EvilDuck can simulate typing commands, passwords, or payloads, just like the well-known USB Rubber Ducky.
  • Automated Payload Execution: With scripts stored on the SD card, EvilDuck automatically reads and executes predefined commands.
  • LED Feedback: The LED indicators help in identifying the status of the script execution or any issues like missing SD cards or scripts.
🧰 Getting Started
Getting started with the EvilDuck project is straightforward. Here's how to begin:
Hardware:
1. Gather Components:
  • ATmega32u4 microcontroller
  • SD card reader
  • SMD LEDs
  • AM1117 3.3V voltage regulator
  • Resistors and wires for connections
  • Male USB A connector
2. Gather Components: ATmega32u4 microcontroller SD card reader SMD LEDs AM1117 3.3V voltage regulator Resistors and wires for connections Male USB A connector
3. Build on Breadboard: If you're experimenting with the EvilDuck and don't have a custom PCB ready, you can assemble the components on a breadboard for testing.
4. Soldering: If you're printing a PCB, solder the components (ATmega32u4, SD card reader, LEDs, and resistors) carefully. The SMD components make this more compact but require precision in soldering.
Software:
1. Install Arduino IDE: EvilDuck scripts are written and uploaded using the Arduino IDE.
2. Set Up Libraries: Make sure to install necessary libraries like Keyboard.h for simulating keystrokes.
3. Write Your Payload: Create your script and load it onto the SD card. A script may look something like:
GUI r
DELAY 500
STRING notepad
ENTER
DELAY 1000
STRING EvilDuck is live!
ENTER
4. Load the Script: Insert the SD card into the SD card reader connected to the EvilDuck and plug it into the target machine.
  • EvilDuck Commands
When creating scripts for EvilDuck, you use a set of predefined commands to simulate keystrokes and control the flow of script execution. Each command performs a specific action, such as typing text, pressing a key, or introducing a delay. Understanding these commands and how to use them effectively is crucial for writing scripts that work smoothly.
Below is an in-depth explanation of the available commands for EvilDuck:
1. STRING
The STRING command types out a string of text, just as if you were manually typing on the keyboard. This is useful for typing out phrases, commands, or any text-based input.
Syntax:
STRING <text>
Example:
STRING Hello, World!
This command types "Hello, World!" wherever the cursor is active.
2. DELAY ...
