Compared to the first generation of ESP Audio Docks, v2 uses top-of-the-range WROOVER modules with 16Mb of Flash and 8Mb of PSRAM. Every board in the range will have an ESP32S3 variant to promote faster S3 adoption in the community. Every board will have built-in or external Wi-Fi antenna options to allow both compact variant and the one designed for challenging connectivity conditions. Ethernet is an optional extra that allows wired board use. Finally, every board will fit a standard Raspberry Pi 4 enclosure allowing a neat look on the budget. All-in-all, v2 is a poor man's Esparagus board, that might not have as many peripherals, but have the same audio capabilities and cost a fraction of the Esparagus equivalent.
Hey folks. A couple of new boards just got released.
First, HiFi-ESP32-Plus is now available in both ESP32 and ESP32-S3 variants. I'm working on the proper support of this DAC, starting with snapclient and squeezelite-esp32, and then the esphome component is coming up. What is exciting about this DAC is built-in 6-band equalizer and crossover, so I'm planning to create a 2.1 system based on that.
Second, Amped-ESP32 is now available in both ESP32 and ESP32-S3 variants, and all will be using the newer TPA3128 amp going forward. What it means is better efficiency, more power, better audio quality, and proper MUTE function.
As soon as PCM5122 support is ready, I'll release Amped-ESP32-Plus, driven by PCM5122+TPA3128, the pinnacle of the DACs I've used, I think
Hey everyone! Just finished the latest addition to the ESP32 Audio family - the HiFi-ESP32 Plus. This one's been cooking for a while, and I'm pretty excited about what it brings to the table.
So the original HiFi-ESP32 has been solid with its PCM5100A DAC, but I kept looking for something with more processing power on the audio side, especially when paired with an amp, as in Amped-ESP32. Enter the PCM5122 - same great audio quality but now with a built-in DSP that can actually do some serious work.
The PCM5122 isn't just a DAC upgrade; it's got a proper digital signal processor inside that can handle:
- Parametric EQ with multiple bands - Digital crossover filters - Dynamic range control - Bass and treble enhancement for downstream DAC (2.1 systems)
Basically, all the stuff you'd normally need a separate DSP chip for, or would have to burn CPU cycles on the ESP32 to handle.
Why This Matters
If you've ever tried to build a proper speaker system with an ESP32, you know the pain of trying to implement crossovers or room correction in software. The ESP32 is great, but asking it to do real-time audio processing while handling WiFi, Bluetooth, and your application logic gets messy fast.
With the PCM5122's onboard DSP, you can offload all that heavy lifting. Want to bi-amp some speakers? Set up the crossover in the DAC. Got a room with weird acoustics? Program some EQ curves. The ESP32 just has to tell the DAC what to do and can focus on being a good network audio player.
Current Status
Hardware is done and tested. The PCM5122 talks I2C, so initialisation code is needed, luckily already created by the community. The fun part is going to be writing drivers to actually use all the DSP features.
I'm planning to start with basic EQ control and volume, then work up to the advanced stuff like crossovers. Planning to integrate it all into ESPHome so you can control everything from Home Assistant.
Also working on an Amped version that pairs the PCM5122 with a TPA3128 amplifier for folks who want the DSP features but with built-in power.
Next Steps
Will focus on the hardware first, moving to the bare ESP32 driver implementation with TI PPC help. Hoping to get some help from the community to port it to ESPHome, squeezelite, and snapclient in the future
Small but colorful update. Starting May 2025, all boards will have an OLED screen solder-less connector. Originally, I added the OLED header on the back side of the PCB that would require careful and skillful soldering (It is quite nice when using squeezelite since you can get quite a lot with existing plugins and settings). Later on, I managed to find the right model of the screen and corresponding connector for a reasonable price, and decided to equip every board with the connector as standard.
At this moment, one can simply throw in a compatible OLED screen and use a small strap of double-sided adhesive to fix it mechanically. The final result is a nice and finished look
Introducing a new board in the ESP32 Audio family - Amped-ESP32. Short version: it is a powerhouse similar to Louder-ESP32 (they sound so similar that I started to suspect they have the same output drivers), but simpler to use and a bit more versatile.
Slightly different angle: It is the next step for the HiFi-ESP32 board, which has the same DAC and 3.5mm output. It adds a powerful TAS3110 D-class amp and can drive large speakers no sweat. You can plug headphones into the 3.5mm as well, the amp will get muted in the case.
Slightly longer story, compared to the TAS5805M of the Louder-ESP32, it lacks DSP capabilities, since it relies on the external DAC to produce an analog signal (PCM5100 in this case). EQ or Loudness processing will have to be done on the MCU instead; that's the price of simplicity.
(Spoiler alert) Next stop is the 2.1 version of the Amped board, but I'm still trying to figure out the best way to implement the LF stage (I'm no good at analog, I'm afraid).
Today, I'm ready to introduce the Loud-ESP32 board and its ESP32-S3 counterpart. This is the second generation of the Loud-ESP board and a direct successor of the Loud-ESP Duo dock.
Like other boards in the ESP Audio series, it is the same size, so you can use it with the Raspberry Pi 4 case. It has a built-in ESP32 module with PSRAM in case (external chips suddenly become inadequately expensive).
Also, I switched to the BGA version of the MAX98357 DAC. It is incredibly small, I had doubts if it can handle the job through those tiny pads. But during testing, no issues were found, it plays as good as the larger-sized QFN16 brother.
The key point of the board is to deliver good quality audio as simple as possible. It can use any USB-C charger delivering little above 2A of current (pretty much any modern phone charger), and it is surprisingly loud for the size.
To chase the low price point I decided to make most of the peripherals optional (like Ethernet or IR reader), so one can add only the things you'd really need.
Great Boards, works 'out of the box'
I made a Audio Compressor / Limiter whitch i described on github:
https://github.com/wavoigt/ESP32-Audio-Dynamic-Compressor
