Starting to throw stuff together...
A project log for [Nite|Nuke] Light
Upcycled X-Ray warning light gets turned into a night light to give atmosphere, as well as spike in intensity with radiation events.
nrrdzillanrrdzilla 02/18/2017 at 08:130 Comments
Ordered Russian SI-22G / SI22G Geiger Tube. Expected delivery around the beginning of March...
Also pulled Solidworks model files, since most users prob won't have access to that. Will likely transition this project onto OnShape, here's the diffuser as a start:
https://cad.onshape.com/documents/cc162031441e680698595b2a/w/eaa2b5ab492bdde8eaa25799/e/3cf96559478af369a68cae4b
If someone could please check to make sure this opens OK, that would be great :)
