Blinky Loop SAO
A small SAO with 12x WS2812 and an accelerometer
This is a simple add on for electronic badges, that includes a circle of WS2812 addressable LEDs and an accelerometer, to sense orientation and maybe also some movements or gestures. It's minimalistic design, makes it especially useable for badges with multiple connectors, that aren't all mounted in the upright orientation and the accelerometer can help adjust animations to always be oriented upright (eg. a simple clock or maybe some pendulum effects). Other project ideas include a digital level, or maybe a game with movement sensing.
Design idea
The idea was to design an add-on, that did not care about how it was mounted with a way to correct for different mounting scenarios.
The relatively small, circular shape with the connector in the middle, makes it fit nicely in most cases and the accelerometer can help show animations up-right, when needed.
Motivate hacking
As there are no microcontroller on this SAO, it is vital for operation, that there is host support with some code running to at least control the LEDs. The string of 12 addressable LEDs (NeoPixels) are connected to GPIO1 of the SAO connector.
The accelerometer is connected via I2C and have it's interrupt 1 connected on GPIO2, which could be used for motion detection or free-fall detection.
There is also a temperature sensor in the accelerometer.
I2C Communication
The LIS2DH address is 0x19 by default, but by cutting a trace and bridging a small solder jumper, it can be changed to 0x18, to prevent address conflicts on the I2C bus.
BlinkyLoop SAO Schematics.pdf
Adobe Portable Document Format - 104.98 kB - 10/22/2024 at 15:44
Preview
  • 1 × LIS2DH12 Semiconductors and Integrated Circuits / Misc. Semiconductors and Integrated Circuits
  • 12 × WS2812b-2020 Addressable RGB LED
  • 4 × 100nF 0603 Capacitor Decoupling capacitor
  • 1 × 10uF 0603 Capacitor Decoupling capacitor
  • 1 × SAO side connector, through hole 2x3, keyed, 2.54mm spacing, male pins
  • Controlling the LEDs from Micropython on the Supercon.8 Badge
    Thomas Flummer11/01/2024 at 21:14 0 comments
    Simple micropython python snippet to control the LEDs on the Blinky Loop SAO
    The neopixel library seems to be already on the micropython image on the badge, to no need to add a library.
    This does a simple rainbow that rotates continuously. It's a little jumpy so there is room for improvement, but the code should be relatively simple to read.
    from machine import Pin
    import neopixel
    import time
    # setup Blinkyloop LEDs (pin 22 is GPIO1 on SAO port 4)
    np = neopixel.NeoPixel(machine.Pin(22), 12)
    def rainbow(np, brightness):
        n = np.n
        color_map = (255, 170, 128, 85, 0, 0, 0, 0, 0, 85, 128, 170)
        while True:
            for j in range(n):
                for i in range(n):
                    r = color_map[i]
                    g = color_map[((i + 4) % n)]
                    b = color_map[((i + 8) % n)]
                    np[((i + j) % n)] = (round(r * brightness), round(g * brightness), round(b * brightness))
                np.write()
                time.sleep_ms(50)
    rainbow(np, 0.1)
  • Testing the components
    Thomas Flummer10/27/2024 at 14:27 0 comments
    I have made a test planform based on the Raspberry Pi Pico module, and for this I will be using the Pico W variant. It doesn't really matter for the test, but it will match the one used on the Supercon 8 badge, though this test platform currently runs Circuit Python, and the code snippets below if based on that.
    The test first runs a little rainbow animation to check that all the LEDs are connected properly, and has survived the soldering, sanding and cleaning.
    import board
    import busio
    import time
    from rainbowio import colorwheel
    import neopixel
    pixel_pin = board.GP26
    num_pixels = 12
    pixels = neopixel.NeoPixel(pixel_pin, num_pixels, brightness=0.1, auto_write=False)
    def rainbow_cycle(wait):
        for j in range(255):
            for i in range(num_pixels):
                rc_index = (i * 256 // num_pixels) + j
                pixels[i] = colorwheel(rc_index & 255)
            pixels.show()
            time.sleep(wait)
    for n in range(2):
        rainbow_cycle(0)
    After that, the LIS2DH accelerometer is tested. Electronut labs has a library for that. I simply connect to the accelerometer, configure it to use the 2G range (regular gravity falls nicely within that), and then show the X, Y, and Z values on the screen.
    import board
    import busio
    import displayio
    import adafruit_displayio_ssd1306
    import time
    from adafruit_display_text import label
    import terminalio
    import electronutlabs_lis2dh12
    # release, otherwise we won't be able to attach to GP15/14, as the display uses them
    displayio.release_displays()
    # initialize DEV board I2C
    i2c_dev = busio.I2C(board.GP15, board.GP14)
    # initialize SAO I2C
    i2c_sao = busio.I2C(board.GP5, board.GP4)
    display_bus = displayio.I2CDisplay(i2c_dev, device_address=0x3c)
    display = adafruit_displayio_ssd1306.SSD1306(display_bus, width=128, height=64)
    # Make the display context
    splash = displayio.Group()
    display.root_group = splash
    # Draw a label
    text = "LIS2DH:"
    text_area = label.Label(terminalio.FONT, text=text, color=0xFFFF00, x=0, y=5)
    splash.append(text_area)
    lis2dh12 = electronutlabs_lis2dh12.LIS2DH12_I2C(i2c_sao, address=0x19)
    lis2dh12.range = electronutlabs_lis2dh12.RANGE_2_G
    # create the label
    x_label = label.Label(
        font=terminalio.FONT, text="x = {} G".format(0), scale=1
    y_label = label.Label(
        font=terminalio.FONT, text="y = {} G".format(0), scale=1
    z_label = label.Label(
        font=terminalio.FONT, text="z = {} G".format(0), scale=1
    # set label position on the display
    x_label.anchor_point = (0, 0)
    x_label.anchored_position = (0, 20)
    y_label.anchor_point = (0, 0)
    y_label.anchored_position = (0, 35)
    z_label.anchor_point = (0, 0)
    z_label.anchored_position = (0, 50)
    # add label to group that is showing on display
    splash.append(x_label)
    splash.append(y_label)
    splash.append(z_label)
    while True:
        # Read accelerometer values (in m / s ^ 2).  Returns a 3-tuple of x, y,
        # z axis values.  Divide them by 9.806 to convert to Gs.
        x, y, z = [value / electronutlabs_lis2dh12.STANDARD_GRAVITY for value in lis2dh12.acceleration]
        x_label.text = "x = %0.3f G" % (x)
        y_label.text = "y = %0.3f G" % (y)
        z_label.text = "z = %0.3f G" % (z)
        # Small delay to keep things responsive but give time for interrupt processing.
        time.sleep(0.1)
    I ended up simple switching out the SAO and resetting the Pico, to run the test for the next on. Tilting the test board will result in different values, and checking that they fall at about 1G pointing down when steady. All the roughly 35 SAOs prepared all worked without any errors. The accelerometer footprint is a little fiddly, but good solder paste application helps in a proper manufacturing.
    This type of WS2812 is a bit tricky, as it's recommended to bake the parts first before assembly, to help eliminate any of them breaking when they go through the reflow soldering. As that belongs to the "Standard" and not the budget PCBA service, I also ended up getting X-rays from when they checked the soldering:
  • Assembly and Cleaning
    Thomas Flummer10/27/2024 at 14:02 0 comments
    I had these boards populated with all the SMD parts and for this, the board was panelized in a 2x2 configuration, with a frame and "mouse bites" (row of small holes in the PCB), to allow separation.
    I positioned the mouse bites outside the edge cut circle, so that they could be sanded away after separation.
    So ease the soldering of the SAO connector, I decided to first half the panels and then using a 3D printed jig, solder in the connectors, before the full separation and sanding.
    The 3D printed jig with small steel dowels that is used to align the board using one of the cutouts for the SAO leash in the PCB.
    The notch in the bottom makes sure the SAO connector is oriented correctly.
    After soldering the connectors, it was time for depanelization.
    They snap relatively easy, but holding the thin rails with a needle nose plier helps a lot with a relatively clean break and protects you fingers when doing many.
    The excess PCB that was sticking out was sanded away with a disk sander. It's a bit fiddly and messy so not an ideal way, but there isn't that many options when you want a fairly clean outer edge on a circular PCB and want machines to assemble the small parts.
    It's not always perfect but should be good enough to not hang on to peoples clothes and maybe get ripped off.
    They end up pretty messy, after being sanded in 4 spots, so to get rid of that and the flux from the soldering, I decided to give them a wash in isopropyl alcohol (IPA), and dry them with paper towel.
    Looks better after cleaning.
View all 3 project logs
Marc MERLIN wrote 03/08/2025 at 20:36 point
Thanks for this SAO, I was able to use it in my project:
- https://marc.merlins.org/perso/electronics/post_2024-11-01_Pasadena-Hackaday-Supercon-2024-SAO-Badge.html
Great to have met in Pasadena, this was fun:
- https://marc.merlins.org/perso/electronics/post_2024-11-01_Pasadena-Hackaday-Supercon-2024.html
