Compact Motion, Temperature, and Humidity Sensor
ESP12-E Based sensor for detecting motion, temperature and humidity in a small and (hopefully) inexpensive package
Hoping to combine some skills I have been working on to produce a small, cheap multi-sensor to integrate into our Smart Home. This project will require coding, CAD design, and maybe some ECAD for a custom board.
The initial design will be around a compact USB charger as a power source, but I may make a design for use in any USB port.
  • 1 × PIR Sensor
  • 1 × AM2302 Temperature/Humidity Sensor
  • 1 × ESP12-E
  • 1 × HT7333 Voltage Regulator
  • 2 × 10 microFarad Cap
View all 9 components
