Casting chest & shin plates
A project log for Elysium Max Exoskeleton
Exoskeleton suit replica from the movie Elysium in Autodesk Inventor, 3D printed and investment cast out of Aluminum
valVal 07/01/2019 at 15:030 Comments
This weekend I made a second attempt at casting chest & shin plates. For the next one I will use thin sprues in addition to thick sprues to prevent parts of the model from breaking off with the sprues.
Wax parts before dipping to build shells around them:
First attempt:
Second attempt:
Both put together, before cleanup:
I will make another attempt at casting the chest plate to see if I can get it even cleaner, and then redo one of the shin plates before there wasn't 100% fill.
