Better mounting for the ejector servo
A project log for Interactive Mario Mushroom Block
Ever want to punch a mario block and get a mushroom to come out? Me too, so I'm building it.
scott-clandininScott Clandinin 04/04/2017 at 23:500 Comments
Well, I probably should have seen this coming but the ejector servo (which was just duct taped to the side of the tin) has pulled off from the weight of the mushroom.
Mounting this is a bit awkward as I don't want to put any screws through the front of the tin. I will use some super glue and re-mount with some duct tape. That should be able to hold it!
