Assembly done for a few giveaways
A project log for Blinkencap
The world s most difficult to manufacture blinkenlight. SAO using the massive overkill that is an ASIC to control a single RGB LED.
pat-deeganPat Deegan 10/24/2024 at 17:550 Comments
Completely a small batch assembly to bring to the con
Made a number of stand-alone units, that use the hex inverter to auto-blink and can be controlled from the badge.
Also managed to bring up some populated with actual ASICs.  Fewer of these, since the chips are kinda precious.
Neat thing is, I've found multiple projects that can be used to play with the LED in different interesting ways :)
Packing them up for the supercon.  Gonna be fun!
