This project is a truly simple SAO. It's a hand-sewn fuzzy felt creature - a hedgehog, to be exact - that lights up.
It's essentially a tiny protoboard with an SAO connector attached to it, some sewable "sequin" LEDs, and a felt covering wrapped around the innards.
The protoboard acts as a little spine or skeleton to hold up the outer felt layers, and provides a way to attach short wire leads with loops that can be connected to the LEDs via conductive thread. Inside the body is an extra piece of felt that the LED's are sewn to and attached to the leads. There's a small bit of diffusion - aka polyfil stuffing - in there to give a more even glow.
I didn't try to hide the stitching - it gives a nice handmade look. I'm pleased with the result and I hope you will be, too!
I intend to make at least a few more of these to share at Supercon 2024 - see you there!
As for the possibility of making multiples of this design, it might be easier with a few changes:
- Protoboard => custom PCB with places to mount LEDs
- Hand cut felt => laser cut felt (or other cutting automation)
- Hand sewn body => glued body
- Embroidered eye => glued on doll eye
I made this SAO with methods I know and stuff I had on hand (mostly - I did buy the protoboards). I don't know how to make custom PCBs and I don't have a laser cutter, for example, so it was all done by hand. I wasn't in a big rush, so I took the time to sew instead of glue. Automating and simplifying the construction would make it much easier to make multiples, but some of the charm - like hand stitches that show - might be lost.
Laura
Chris
todbot
