Remote Observatory Dome controller
using Raspberry Pi's to automate the open/close and rotation of an observatory dome using MQTT linked to web pages for remote access
using more than one processor to automate an observatory dome to a fully robotic control: Shutter and dome rotation, focus, dew heaters and link to Stellarium, perhaps a webcam and weather station etc. VERY EARLY DAYS.
  • 1 × Raspberry Pi Zero £4 from the Pi Hut
  • 1 × Pimoroni - EnvironpHat Pi hat, giving analogue inputs and motions, Gauss measurements (electonic compass) (£15)
  • 1 × Box to hold pi & hat ABS box c30mm x 70mm x 55mm or simliar
  • 1 × Power Supply converter: 12v to 5v at 1amp. Will feed the project via 12v recvhargeable, so need a converter to run Raspi
  • 1 × 12v rechrageable cell prefer LiPo cell, but safer to use lead acid. Needs enough to drive a shutter mechanism for 2 mins and the pi for some 5 hours. guess at 35Ahr. Needs to work in low temperatures
View all 7 components
  • Software
    Rob Jones02/12/2017 at 17:49 1 comment
    Raspi Pi: OS loaded and updated to include:
    SAMBA: allows remote file services from a networked PC, when Pi in headless mode
    MQTT client: messaging system
    {Wiring Pi}
    Pimoroni EnvironpHat: software libraries to communicate with the Hat. Need access to .heading()
View project log
  • 1
    Step 1
    Most hardware has been bought to be 'plug and play',
    Raspberry Pi, wireless dongle power supply and EnvironpHat are plug-n-play together in only one way!
  • 2
    Step 2
    Software OS
    follow the standard OS install on the Raspoberry pi.org site, then add
    sudo apt-get: samba pomoroni MQTT-client
View all instructions
