Hackaday.io Hackaday.io
Sign up Log in
LED Maze Solver
An LED maze solver using the Arduino microcontroller and MAX7219 LED driver
sebastian-jimenezSebastian Jimenez
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
70
0
0
1
Team (1)
  • sebastian-jimenezSebastian Jimenez
Join this project's team
  • Source Code
  • Video
hardware
completed project
arduino led max7219 MAZE Pathfinding
This project was created on 10/14/2024 and last updated a year ago.
Description
I designed and built an LED maze solver using an Arduino microcontroller, which generates a random maze and solves it using the A* pathfinding algorithm. The maze is solved almost instantly in each iteration, with a dot visually tracing the solution on the LED display.
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Building a LED cube drived by an Arduino Uno
Project Owner Contributor
3x3x3 LED cube
grgory-paulGrégory Paul
LED Matrix using Pixel Blaze
LED Box
morganmorgan
Arduino library for driving hundreds to thousands of WS2811, WS2812 or INK1002 addressable RGB LEDs.
OctoWS2811 LED Library
paul-stoffregenPaul Stoffregen
Circular LED lamp
LED LAMP
julienJulien
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "LED Maze Solver", please tell us the reason.
Send message
Remove Member
