Progress! Data from the tablet.
A project log for WiiChuck
A Wii controller library for talking to every Extension Controller made for the wii including Nunchuck and Classic Controller over i2c.
alex-camiloAlex Camilo 02/18/2017 at 01:150 Comments
I repeaded the sequence of reads and writes exactly.
Writing a full 16 bytes of key, reading a few times, and then setting 0xfb to 01 seems to yeald results.
The tablet is now spitting out 6 bytes that change with the stylus. I need to fix my decryption function or try the 0xfb 01 trick in unencrypted mode before i can begin decoding stuff.
Accessory Bytes:	FD 5A 4D 51 0E 5E
Accessory Bytes:	10 43 75 5E 0E DE
Accessory Bytes:	A7 42 AC 53 48 DA
Accessory Bytes:	9D 42 A5 52 5A D5
Accessory Bytes:	58 42 65 52 BE D5
Accessory Bytes:	59 42 7E 52 78 D5
Accessory Bytes:	5B 42 40 52 25 DA
Accessory Bytes:	44 42 AE 52 01 D5
Accessory Bytes:	7A 42 15 53 AA D5
Accessory Bytes:	9B 42 EE 53 3E D5
Accessory Bytes:	AE 42 ED 53 78 D4
This is the startup procedure so far. I'm not sure how much of these extra delays or reads i need. I was tryig to match what the wii does.
        Serial.println("enc start");
        // to start, init in unenc mode
        _writeRegister(0xF0, 0x55);
        _writeRegister(0xFB, 0x00);
        delay(100);
        _burstReadWithAddress(0xfa);
        delay(100);
        _writeRegister(0xF0, 0xAA); // enable enc mode?
        delay(90);
        _burstWriteWithAddress(0x40,_key_table_1,8);
        _burstWriteWithAddress(0x48,_key_table_1+0x8,8);
        delay(100);
        _burstReadWithAddress(0x20);
        _burstReadWithAddress(0x28);
        delay(100);
        _burstReadWithAddress(0x30);
        _burstReadWithAddress(0x38);
        delay(100);
        _burstReadWithAddress(0x00);
        delay(100);
        delay(100);
        _writeRegister(0xfb,0x01);
        delay(100);
        delay(100);
