I think we have good data.
A project log for WiiChuck
A Wii controller library for talking to every Extension Controller made for the wii including Nunchuck and Classic Controller over i2c.
alex-camiloAlex Camilo 02/18/2017 at 03:510 Comments
According to the wiibrew wiki the following is true.
decrypted_byte = (encrypted_byte XOR table1[address%8]) + table2[address%8]
if the host key is 16 zero bytes, table1[x] and table2[x] are all 0x97.
So i set the key to zero and simplified my decryption function and started pulling some more data. When I approached the board with the pen I saw byte 5 go from 0x80 to 0x00 and when i applied pressure it counted up from 0 to 7.
I think this is the first useful bit of structure i've gotten so far. I can detect a pen and sense pressure with 3 bits of sensitivity. There is totally more pressure data in byte 5 but it looks like there might be something else. it's not counting from 00 to FF correctly.
