My board is still bricked, and no more board I can buy to continue.
However experiment in pure RISC-V has not ended, I just use Claude Code now to create the pure assembler output for all the boards I have in my posession.
When you connect a logic analyzer to the debug LED pin, thenb Claude Code can automate build, flash, test, build, flash, test....
