Supercon Add On (SAO) infinity mirror. PCB board, two laser cut acrylic mirror and a bunch of LEDs all encased in a 3D printed housing. This SAO will hopefully provide an interesting display of light as people pass by each other. There are some traces and through holes that I left in just in case I want to try some things. Possibly add a potentiometer (dimmer) in the R2 location (I would need to cut a trace for it to work correctly). Alternatively I could use one of the GPIO pins to control the power with PWM (I probably will not get around to this but the extra traces are there if wanted.)
Scorch Works
DIY GUY Chris
I feel like this thing turned into RGB rainbow mode would be trippy. 😂 Very cool!
