1Must have:
The absolute encoder requires a magnet mounted on the motor's output shaft, positioned 6mm from the sensor. For geared systems, mount on the output shaft or account for reduction ratio in software. Standard N42/N45 magnets recommended (40-90mT field strength at sensor).
