Update 12/17/2024:
Researched different ICs for controlling a full 6-dot braille cell.
TLC6C5912-Q1 12-bit shift register, to control all 12 outputs associated with the full cell. Two outputs are required for each dot to drive current in both directions.
DRV8212DRLR H-bridge motor driver IC, to take digital signal from shift register and enable current flow in a specified direction.
Completed PCB v4 design:
3D render:
KiCad design:
Completed PCB v4 Schematic:
(coils not shown)
Basim Cheema-Sabir
