————————Supplies————————
crowbits-uno
crowbits-pir-sensor
crowbits-ir-reflective-sensor
crowbits-mp3
crowbits-rgb-matrix
——————Step-by-step guide——————
Step 1:
Buy a plastic jack-o’-lantern about 20cm in diameter, cut a hole in the nose, and use hot glue to fix a Crowbits PIR sensor in it.
Step 2:
Use a knife to make holes in the eye area, and use hot glue to fix a Crowbits RGB Matrix behind the hole.
Step 3:
Install the master controller Crowbits_UNO, Crowbits_MP3, speaker, Crowbits-IR,Reflective Sensor. Then program and debug the whole process.
*Note: You need to put the downloaded sound material into the SD card in advance.
Step 4:
Install the Crowbits-IR Reflective Sensor on the inside top of the pumpkin lantern, place the master controller and speaker inside the pumpkin lantern, and cut a small hole in the lid to let the candy in. Turn on the power and the whole program starts to run.
Once the PIR Sensor detects a human, it will activate the lantern program. Its eyes light up and will make a ghost howl simultaneously. When a candy is put in, it will be detected by the IR Reflective Sensor, and the lantern will turn off its eyes and stop howling.
Joshua A.S.
Julius Curt
blorgggg
Circle Electronic
