HORIZONTAL 3D PRINTED WIND TURBINE 15-20 WATTS
This prototype is a simple horizontal wind turbines with innovative new turbines. Just 3d print it and tell us your own impressions!!
Public Chat
***This prototype is part of a bigger collection of other much more big, powerful and with counter rotation features horizontal/vertical wind turbines 3d printed portable devices that are included in our next Kickstarter Campaign https://www.kickstarter.com/projects/459381052/turbine-birds-project and you can view a trailer video here https://youtu.be/I_UZFu5VU4I We have designed and improved this portable small horizontal wind turbine from one DC motor generator to a dual DC motor version to generate more power with more other improvements like an innovative blade. For this prototype it will be used the following materials with the links to where to purchase them, - Bearings (8mm x 22mm x 7mm) - Uxcell RF500TB-12560 DC5V-12V 2300RPM-5600RPM no load speed 32mm diameter DC motor or equivalent - Optional but strongly suggested to place the device in a base holder In the detailed description the links are provided and detailed pictures of the device assembly with stl fil
The supports of the system are of 2 types, the conventional one, which is the first picture below and another supporter that combines with a base holder (second picture). The STL file name for this second support that it is inserted in the base holder as it can be viewed in the pics is BottomSupporterToBaseHolder.stl
The best option in my humble opinion is to use a base holder to hold all the device as the second picture shows.
As the image below shows, we have developed a blade (left) that is wider and have an special structure that gives more impulse than a traditional blade as the one on the right of the pic.
Configure the Wind Turbine for the Different Wind Forecasts
The device can be configured for placing a gearbox with range of 10x1 or reduce the hardness of the gearbox if there is not a low of wind available or it is needed to generate more RPM, by changing the gears to a range of 3x1. It can be done also by placing one or two dc motors.
                    Innovation Developing New Counter Rotation Devices
Here you have some pictures and videos showing the developments of this new innovative devices for our next Kickstarter campaign. If you like it, just follow the project to encourage us in this adventure!!!
3x1BigGear(1).stl
Standard Tesselated Geometry - 471.76 kB - 10/26/2024 at 23:18
Download
MainBodyPlatformDCGearSystem.stl
Standard Tesselated Geometry - 164.44 kB - 10/26/2024 at 23:18
Download
3x1SmallGear.stl
Standard Tesselated Geometry - 93.83 kB - 10/26/2024 at 23:18
Download
ShaftToBigGears.stl
Standard Tesselated Geometry - 32.80 kB - 10/26/2024 at 23:18
Download
10x1SmallGearDCDirect.stl
Standard Tesselated Geometry - 88.66 kB - 10/26/2024 at 23:18
Download
View all 18 files
  • 8 × Bearings (8mm x 22mm x 7mm) www.amazon.ca/dp/B0CWL9JQ2P?ref=ppx_yo2ov_dt_b_fed_asin_title
  • 2 × Uxcell RF500TB-12560 DC5V-12V 2300RPM-5600RPM no load speed 32mm diameter DC motor or equivalent www.amazon.ca/-/fr/RF-500TB-12560-DC5V-12V-2300RPM-5600RPM-Vitesse-Diamètre/dp/B00QBZ1SX6/ref=sr_1_1?keywords=uxcell+rf-500+tb-12560+DC5v-12v+2300+RPm-5600+rpm+no+load+speed+32+mm+diameter+dc+motor&qid=1670192199&sr=8-1
  • 1 × Optional but strongly suggested base holder www.amazon.ca/dp/B07T83T6FT?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
  • 1 × 3d Printer filament You will need just 1/2 kilo of filament even less to build this device
  • 1 × 3d Printer ideal bed size The height in the z-axis must be 280mm minimum but in case you want to print it and you have less height, email me to esposcar@kolibriwindstorm.com
  • 1
    Step 1
    Assembly Picture by Picture Using the Conventional Support System and Stl Files
View all instructions
