close-circle
Further refinements to export code
A project log for Noo-D(l)eus Ex Machina - Freeform PCB design proto
The very first prototype PCB testing the new pcb-rnd->FidoCadJ->pcb-rnd toolchain easing freeform bezier & cubic spline track/PCB creation.
a1039181 02/24/2017 at 15:430 Comments
The text is behaving pretty well with round trip testing pcb-rnd -> FidoCadJ -> pcb-rnd
and footprints have been improved with circle, silk rectangle and minimum line thicknesses for silk elements
If all goes well, there should be some FidoCadJ equivalent footprints on gedasymbols.org soon....
And here's an example gerber output of the Semiconductor footprints....
