FidoCadJ code git pull request done
A project log for Noo-D(l)eus Ex Machina - Freeform PCB design proto
The very first prototype PCB testing the new pcb-rnd->FidoCadJ->pcb-rnd toolchain easing freeform bezier & cubic spline track/PCB creation.
a1039181a1039181 02/26/2017 at 12:480 Comments
The export module code has been submitted to the FidoCadJ mainline from my fork
https://github.com/erichVK5/FidoCadJ/
Anyone wishing to give export to gEDA pcb-rnd/PCB a go before the new export module is integrated into mainline can build from my branch.
you simply git clone the repo
cd into it the directory, then
"make rebuild"
assuming you have the usual toolchains and Java installed
