Stage 2 is working!
A project log for µLind (micro-lind)
- a 6x09 based retro computer
eric-lindEric Lind 04/01/2025 at 18:590 Comments
Today we finally got the stage 2 to work properly, we got a led blinking!
We started with a small code that should cycle thru the colors of the rgb led we got connected to a register.
When we tried the code the led only blinked once and was dark after that. When we looked in to the schematics we found that we were generating a active low enable signal from our address-logic and the 373 chip needed active high logic.
Easy fix, we just change a line in the GAL code:
PIN 14		= !EXP_EN	; /* Enable Expansion Port     */
PIN 15   	= !VDC_EN	; /* Enable Video Port         */
PIN 16    	= !SNDR_EN	; /* Enable Sound Port Right   */
PIN 17    	= !SNDL_EN	; /* Enable Sound Port Left    */
PIN 18		= !CF_EN	; /* Enable Compact Flash      */
PIN 19    	= !PAR_EN	; /* Enable Parallel Port      */
PIN 20    	= !SER_EN	; /* Enable Serial Port        */
PIN 21    	= PWR_EN     	; /* Enable PowerLed Port      */   <--- HERE!
PIN 22    	= !IRQ_EN       ; /* Enable IRQ Handler        */
PIN 23   	= !MEM_EN       ; /* Enable MMU                */
 After we fixed that we got it to light up, but not change color... Hmmm...  After some looking at the code we realized that if the stack was not properly set up the jump instructions used in the delay would not work. Said and done, we updated the code and added initialization of the bank register for good measure :
    org $FE00
PWR_LED     EQU $F405
BANK_REG_0  EQU $F400
BANK_REG_1  EQU $F401
BANK_REG_2  EQU $F402
BANK_REG_3  EQU $F403
_START:
    clrb
LOOP:
    stb PWR_LED
    ldx #$03E8
    jsr DELAY_MS
    cmpb #$07
    beq _START
    incb
    bra LOOP
DELAY_MS:
    lda #$7C            ; 2 cycles
DELAY_MS_LOOP:
    nop                 ; 1 cycle
    nop                 ; 1 cycle
    nop                 ; 1 cycle
    deca                ; 1 cycles
    cmpa #$00           ; 4 cycles
    bne DELAY_MS_LOOP   ; 3 cycles
    nop                 ; 1 cycle
    nop                 ; 1 cycle
    nop                 ; 1 cycle
    nop                 ; 1 cycle
    nop                 ; 1 cycle
    nop                 ; 1 cycle
    leax ,-x            ; 5 cycles
    cmpx #$0000         ; 4 cycles
    bne DELAY_MS        ; 3 cycles
    rts                 ; 4 cycles
STACK EQU $1000
    org $FF00
HOOK_RESTART:
    ; Initialize the 6309 CPU in native mode
    ldmd #$01
    ; Initialize the bank registers
    clra
    sta BANK_REG_0
    sta BANK_REG_1
    sta BANK_REG_2
    sta BANK_REG_3
    ; Set up the stack
    lds #STACK
    lbra _START
HANG:
    bra HANG
    org $FFF0
vrestart: fdb HOOK_RESTART
 With this fixes the power led started cycling as expected! IT WORKS!
This means that following works:
Next up is to get the serial port working, my son is working on a SREC parser so we will be able to upload code to execute and run.
