The coding portal gets a slight makeover. We make the code editor larger, with a smaller console (so that it renders nicely on small screens), and add in more activities that you can load in to play, and load the solution to check.
Source code for the wheel robot is also in the making and coming to the portal shortly.
Nguyễn Phương Duy
