🛠️ Project|Forge - Organize Your Projects with Ease
Do you have Arduino sketches, random STL files, and project folders everywhere? Project|Forge is here to transform your chaotic workspace into a maker’s paradise.
📑 Features:
  • Auto-detection: Identifies Arduino, PlatformIO, and other common project types.
  • Folder Organization: Structures code, CAD files, docs, and hardware neatly.
  • Windows-Friendly: Optimized for WSL, great for mixed-OS setups.
  • Beginner and Expert Friendly: Setup options for beginners, WSL users, and Linux pros.
🎯 Ideal for:
  • Arduino, PlatformIO, or multi-software projects
  • Organizing scattered code snippets, 3D models, and docs
🚀 Quick Start:
Install Required Tools (WSL/Linux)
sudo apt update && sudo apt install python3 python3-pip python3-yaml git
Clone the Repo and Run Project|Forge
git clone https://github.com/Kalougear/ProjectForge.git
cd ProjectForge
python3 -m project_forge
📂 Example Folder Structure
After Running Project|Forge:
MyProject/
├── software/       # Source code
├── hardware/       # Schematics, PCBs
├── cad/            # CAD files, 3D models
├── _docs/          # Documentation
└── builds/         # Build outputs
🆘 Troubleshooting
  • Path Not Found: Ensure WSL paths (/mnt/c/...) are used.
  • Python Issues: Run sudo apt install --reinstall python3 python3-pip.
  • Script Errors: Ensure you're in the ProjectForge directory.
📂 Real-World Examples
  1. Arduino Project - Before: messy Desktop, After: organized into structured folders.
  2. Code Snippet Archive - Organizes loose code into reusable modules.
💡 Pro Tips
  • Use descriptive project names.
  • Use ONGOING for active projects, and DONE for completed ones.
  • Keep code snippets in Code_Archives for easy access.
📝 License
MIT License - For makers, by makers!
🤝 Contribute
Check out our GitHub repo to suggest features or contribute.
