XTMax is a software-defined 8-bit ISA card which uses a Teesny 4.1 microcontroller board that provides the functionality of THREE vintage ISA cards. It can expand “conventional” motherboard RAM up to 640 KB, adds 4 MB of Expanded RAM, and provides hard-drive access using a MicroSD card. A small PCB is used to allow nearly all of the ISA bus signals to attach to the Teensy 4.1.
A similar project to this is the PicoMem which is also a software-defined ISA expansion card, however the Teensy 4.1 used on the XTMax is nearly 3X faster than the Raspberry Pi Pico so does not share some of its limitations.
The first feature of XTMax is that it can expand the motherboard’s conventional (motherboard) ram up to 640 KB without limitation and with zero wait states. XTMax also has no limitation on the ability to support DMA to and from the computer’s floppy or spinning hard disks as PicoMem does.
XTMax can currently support 4 MB of Expanded RAM with the current drivers. The Teensy 4.1 has two memory footprints so 8 MB or more can be added if drivers are written to support it.
XTmax also allows a MicroSD card to be accessed as a hard drive which is similar to the functionality of an XT-IDE card.
The pictures show the XTMax installed in a very early IBM 5150 rev-A which has 64 KB installed on the motherboard.
It shows that 4 MB of Expanded RAM was added and that the MicroSD card is accessible as the C: drive. The older IBM PC’s did not display the total amount of conventional memory, but in this application below the memory is expanded to the maximum of 640 KB.
It is worth noting that the first BIOS version of the IBM PC did not support extension ROMs and therefore do not support hard disks, so XTMax is currently the only way to have a hard disk equivalent on these machines!
Ted Fried
Carson Herrington
EtchedPixels
gbm
