Added The Feature to Display incoming Signals to the Jacks. When the Jacks are Unplugged You can Visually see Incoming Signals. When you Plug a jack in the LEDs are Disconnected to prevent any Voltage Drop to the Patch. The module is still passive and I think it is Quite a clever way to add some Visual Feedback to this module. Still got a few Refinements to do. Before I order the First Prototype.
