Ordered some Green versions of my VinesLink module. Lucked out twice. Had to drill out more panels. Because the 3.5mm PCB Holes didn't fit again. I must of sent the wrong panel revision. But I got the Drill to burr. Really like how the Green Panels Turned out. They really Vibe with the Jungle Theme. Really Like the added Feature of the inside case Jack as a option for routing.
