Third Test Paddle
After cutting off the rear cross-beam I went for a third test paddle. This time I paddled to a near by bridge and back again (2.8 km return). I am far from being a young, fit and an experienced canoeist, took me 39 minutes or 4.3 km/hr. The canoe hull speed 8.5 km/hr (you would need an outboard motor to go any faster!), so plenty of room for improvement. My target is 6 km/hr so I need to do it in 28 minutes. It will take me a while to get to this speed no doubt.
The weather in Perth Western Australia even in winter is mild the average maximum is about 19 degrees C in June. Today it was 19 degrees C when I arrived and about 22 degrees C when I left. The down side is that the UV index down here is pretty extreme. You need to acclimatise to the sun or you will get burnt to a crisp!
Here is the latest picture of my canoe:
Here is a closeup of the cutoff rear cross-beam:
Weathercocking
The canoe weathercocks quite badly when paddling into the the wind (what little there was!). four strokes to one. Downwind it tracks quite well. I need to fix this. One option is a small skeg to increase the tracking (at the expense of maneuverability). A trimming rudder is another option but best to keep it simple if I can.
Splash Canopy
Another must is a splash canopy (I think it is called a spray cover or spray deck). Not very cool to get in dry and get out soaked because of drips from the paddles. I am thinking of a tilt up frame that would look like this (crowned at the rear):
(source:http://www.newfound.com/images/eclipsehalfskirt.jpg)
Buoyancy Tanks
I need to consider buoyancy tanks. In the event of a capsize (really?), I can up right the canoe by tying a rope the pontoon (handle), standing on the upside down canoe hull and pulling it over:
He says "Give it a try - it is easier than you would think."
(source: https://www.thebeachcats.com/forums/viewtopic/topic/12778).
Fourth Paddle
Had a fourth paddle and managed 5 km/hr but really I need focus on paddle technique and increasing my back flexibility (I am lucky to touch my knees!).
Skeg
My partner is using my car for a few days so I am stuck at home. So I added a skeg to to the canoe. No science to this, just approximately what I have seen before:
I used a hot air gun to strip the paint before fixing the skeg. The primer is really tough to get off so I did not try too hard (its not going to debond easily). I have fixed the wood with mould preventer and will use some fiber-glass tape toughen it up for scrapes before repainting.
Cross Beam Failure
Failed in torsion (probably failed during transport while on the trailer):
And:
I should have fibre-glassed the joint when I had the chance. This will take time to fix as I have to detach all the joints, sand the surfaces back to wood and start again. But after I work out what to do.
Regards AlanX
