Mini-KayakLayout2.dxfA DXF version of the updated lofting layoutAutoCAD DXF - 189.95 kB - 04/01/2017 at 05:23 |
Mini-KayakLayout2.dcThe original DeltaCad file of the lofting layoutdc - 6.35 kB - 04/01/2017 at 05:22 |
ExportLayoutOffsets.basA macro to export a sorted list of offsets for loftingbas - 1.52 kB - 04/01/2017 at 05:23 |
LayoutOffsets.CSVYep, the lofting offsets (load into a spreadsheet for printing).ms-excel - 6.07 kB - 04/01/2017 at 05:22 |
Mini-KayakLayout.dxfA DXF version of the plywood cut-out shapes.AutoCAD DXF - 158.17 kB - 03/31/2017 at 13:16 |
BoatOffsetTable.docxA guide for how to use the following macros.document - 244.80 kB - 03/31/2017 at 13:06 |
BoatOffsetTable.xlsmAn Excel workbook inputting the Hull Offsets Table and a macro to export them to a CSV file for the DeltaCad macro. Also contains some basic hull calculations.12 - 106.93 kB - 03/31/2017 at 13:06 |
BoatOffsetTable.basThe DeltaCad macro to import the Hull CSV file and to convert the 3D hull to 2D cut out shapes.bas - 38.58 kB - 03/31/2017 at 13:06 |
Mini-Kayak.dcThe DeltaCad design file for the plywood cut-outs.dc - 14.75 kB - 03/31/2017 at 13:06 |
CanoeBasicDesign.xlsxBasic Canoe Design Metrics and Calculationsapplication/vnd.openxmlformats-officedocument.spreadsheetml.sheet - 18.05 kB - 02/23/2017 at 07:53 |
CanoeTable.xlsmReads a 3D Hull Offset Table and creates a 2D Unfolded Offset (Cut Out) Table.application/vnd.ms-excel.sheet.macroEnabled.12 - 402.13 kB - 03/08/2017 at 13:55 |
MiniKayakTable.xlsmA mini-kayak by Bruce C. Anderson, seehttp://buckwheat-anderson.com/bcanderson/Boatz/OSKayak/OSKbuild.html It makes a nice pontoon. application/vnd.ms-excel.sheet.macroEnabled.12 - 294.39 kB - 03/15/2017 at 08:01 |
HeartsDesireIITable.xlsmJust trying out the code on something different.application/vnd.ms-excel.sheet.macroEnabled.12 - 385.79 kB - 03/08/2017 at 13:26 |
