Doesn't work on 64bit windows
A project log for install-avr-tools
Given Windows with some version of Arduino installed, set the paths to allow using avr-gcc/etc from the command line.
westfwWestfW 02/24/2017 at 09:320 Comments
A new version (a bit cleaner, and fixing the comment-related bugs) has been committed.
Also, I tried testing with W8.1, and noticed that the current script won't work with 64bit Windows systems (probably W7, W8, or W10); all the previous W10 testing was done with a 32bit install. This is a simple matter of only searching in %ProgramFiles% and not %ProgramFile(x86)%, so it shouldn't be hard to fix.
