Marvin
The paranoid android.
A miniature model of the Marvin from the Hitchhiker's Guide to the Galaxy movie, controlled by a Micro:bit.
  • Walking
    deshipu03/09/2017 at 14:59 0 comments
    After a few tests with walking, I decided to not give it a huge head after all. I tried a number of different heads (including several acrylic globes from a crafts store, a doll's head and a lightbulb) and finally settled on a cardboard outline. This is something that an 11-years old can see and say "I could do that!"
    For now I used the same code for walking as the #Micro:Bob (I just had to swap some pins and adjust trims), but I want to make it controlled from a second Micro:bit.
    import microbit
    class Servo:
        def __init__(self, pin, trim=0):
            self.pin = pin
            self.trim = trim
            self.position = 90
            self.set_period()
        def set_period(self):
            self.pin.set_analog_period(20)
            self.write(self.position)
            microbit.sleep(80)
            microbit.sleep(80)
            self.pin.write_analog(0)
        def write(self, degrees):
            self.pin.write_analog(int(25 + 100 * degrees / 180 + self.trim))
            self.position = degrees
        def move(self, degrees, delay=5):
            if degrees > self.position:
                step = 1
            else:
                step = -1
            for position in range(self.position, degrees, step):
                self.write(position)
                microbit.sleep(delay)
    class Robot:
        NORMAL_FACE = microbit.Image(
            "42024\n"
            "90009\n"
            "00000\n"
            "61016\n"
            "27972\n"
        RIGHT_FACE = microbit.Image(
            "24024\n"
            "09009\n"
            "00000\n"
            "81001\n"
            "28952\n"
        LEFT_FACE = microbit.Image(
            "42042\n"
            "90090\n"
            "00000\n"
            "10018\n"
            "25983\n"
        def __init__(self):
            self.feet_servo = Servo(microbit.pin2, -2)
            self.left_servo = Servo(microbit.pin1, 4)
            self.right_servo = Servo(microbit.pin0, 4)
            microbit.display.show(self.NORMAL_FACE)
        def right_step(self):
            microbit.display.show(self.RIGHT_FACE)
            self.feet_servo.move(120)
            self.left_servo.move(60)
            self.right_servo.move(60)
            self.feet_servo.move(90)
        def left_step(self):
            microbit.display.show(self.LEFT_FACE)
            self.feet_servo.move(60)
            self.right_servo.move(120)
            self.left_servo.move(120)
        def right_half_step(self):
            microbit.display.show(self.NOLRMAL_FACE)
            self.left_servo.move(90)
            self.right_servo.move(90)
        def left_half_step(self):
        def walk(self, steps=1):
            step = 0
            for step in range(steps - 1):
                if step % 2:
                    self.left_step()
                else:
                    self.right_step()
            if step % 2:
                self.right_half_step()
            else:
                self.left_half_step()
    robot = Robot()
    robot.walk(8)
  • The Base
    deshipu03/07/2017 at 16:40 0 comments
    So this is a successor of the #Micro:Bob robot, that would be a little less "gangsta". I designed a PCB for attaching everything together -- the micro:bit, the servos and the battery -- so that you don't have an ungodly mess of wires held together with two-sided tape. I also left some extra holes in the PCB to which you can solder paperclips, to build on top of it and make it a little more interesting.
    I found a nice method of mounting the micro:bit to the PCB without using the bulky edge connection -- just use loops of wire made out of paperclips, and plastic bolts (to not damage the micro:bit). The servos fit right into the slots -- I just made the screw holes a bit too tight, had to enlarge them a bit later. The battery holder is still attached to the backs of the servos with a two-sided tape -- there is no room on the board for a different way of attaching it, unfortunately.
    In hindsight, I should have made more sockets for the servos -- letting you to plug several servos to the same pin, so they move together, so that you can make hands that move together with the legs, etc. -- maybe in the next version.
View all 2 project logs
