Check the github for more informations.
Here the Discord link : https://discord.com/invite/qbwAJch25S
All Evil-M5Project Features
- WiFi Network Scanning: Identify and display nearby WiFi networks.
- Network Cloning: Check information and replicate networks for in-depth analysis.
- Captive Portal Management: Create and operate a captive portal to prompt users with a page upon connection.
- Credential Handling: Capture and manage portal credentials.
- Remote Web Server: Monitor the device remotely via a simple web interface that can provide credentials and upload portals that store files on an SD card.
- Sniffing probes: Sniff and store nearby probes on an SD card.
- Karma Attack: Try a simple Karma Attack on a captured probe
( What is a Karma attack ? check the blog : https://7h30th3r0n3.fr/does-your-machine-have-a-good-or-bad-karma/)
- Automated Karma Attack: Try Karma Attack on nearby probes automatically.
- Bluetooth Serial Control: You can control it with Bluetooth.
- Wardriving: Wardriving with Wigle format output on SD.
- Beacon Spam: Generate multiple SSIDs around you.
- Deauther: Send deauthentication frames and sniff 4-Way handshakes and PMKID in parrallel.
- Client Sniff And Deauth: Sniff clients connected to AP and auto deauth while sniffing EAPOL.
- EAPOL/Deauth detection: Detect deauthentication packets, 4-Way handshakes, PMKID, and pwnagotchi near you.
- Wall Of Flipper: Detect and save Flipper Zero with Bluetooth enabled near you and detect BLE SPAM.
more details here : https://github.com/K3YOMI/Wall-of-Flippers
- Send Tesla code with RFunit: Use RFunit to send Tesla codes, mimicking Flipper Zero capabilities.
- Scan Network and Port: Perform network and port scans to discover devices and services, checking hosts' status.
- SSH Shell: Connect to SSH servers directly from the device, allowing command execution via an on-device shell.
- Web Crawler: Crawl websites to extract information, ensuring authorization to crawl before use.
- PwnGrid: Spam face and message on pwnagotchi devices nearby, causing a Denial of Screen PWND.
more details here : https://github.com/7h30th3r0n3/PwnGridSpam
- Skimmer Detector: Detect potential Bluetooth skimmers using HC-03, HC-05, and HC-06 modules.
- BadUSB: BadUSB attacks by emulating keyboard/mouse inputs to execute predefined scripts or commands with provided script.
- Wardriving Master: Perform Wardriving with wardriving slave esp32 to map networks in a defined area, analyzing signals and identifying access points.
- WebUi BadUSB: Start BadUSB attacks via a web interface.
- Wi-Fi Channel Visualizer: Visualize the number of nearby Wi-Fi on each channels.
- Client Sniff: Capture traffic from connected clients to analyze communications and detect potential vulnerabilities and informations leak.
- Raw Sniffing: Conduct raw packet captures for in-depth analysis of exchanged WiFi network data.
- Handshake Master: Capture and analyze WPA/WPA2 handshakes with Sniffer Slave on static channel.
- Customing Theming: Customize the tool’s interface and themes to tailor the appearance for specific preferences or mission needs.
- Full Network Scan: Conduct a full network scan to identify connected devices, 70 open ports, and running services.
- Reverse TCP Tunnel: Use remotly from anywhere the WebUI.
7h30th3r0n3
Samuk
Wei Wang
Richard Myers
