close-circle
Automajick Cat Toy
A servo controlled mirror and light source to amuse felines
close
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Goal to create a toy to shine and move non-laser light in a fashion appealing to felines. Use of a 2 axis, servo controlled gimbal for the mirror and a RGBW LED light source. Will probably end up needing a 3D printed base to house it all and make it eye safe. The machine will have a serial of pre-programmed patterns to keep kitty engaged and use a PIR sensor / timer to determine when she loses interest.
This is currently a placeholder to capture all my ideas and hopefully capture as I turn it into an actual project.
Pictured are test subjects "C" (Calico) and "J" (Tabby).
