After spending a lot of time with the accelerometer sample code in Arduino and mapping my movements to a CSV, I wrote some code to handle the RPS when the arm is moved in the normal "throwing chops" motion.
#include <Wire.h>
#include <Adafruit_MMA8451.h>
#include <Adafruit_Sensor.h>
#define TIMEUPDOWN 150
#define TIMEBETWEEN 800
#define THRESHDOWN -8000
#define THRESHUP 8000
Adafruit_MMA8451 mma = Adafruit_MMA8451();
int fistPumpCount = 0;
int lastUp = 0;
int lastDown = 0;
void setup(void) {
Serial.begin(9600);
Serial.println("Let's throw chops!");
if (! mma.begin()) {
//Serial.println("Couldnt start");
while (1);
//Serial.println("MMA8451 found!");
mma.setRange(MMA8451_RANGE_2_G);
void loop() {
unsigned long timeStamp = millis();
mma.read();
int fistPump = mma.y;
if(fistPump > THRESHUP) {
int timeDiff = timeStamp - lastUp;
if( timeDiff > TIMEUPDOWN ) {
lastUp = timeStamp;
if( timeDiff < TIMEBETWEEN ) {
fistPumpCount++;
} else {
fistPumpCount = 1;
Serial.print("Pump Up: ");
Serial.print(fistPumpCount);
Serial.println();
if(fistPumpCount == 3) {
randomSeed(timeStamp);
int roshambo = random(1,4); // Stupid exclusive bit
switch(roshambo) {
case 1:
Serial.println("Rock");
break;
case 2:
Serial.println("Paper");
break;
case 3:
Serial.println("Scissors");
break;
fistPumpCount = 0;
Chad Lawson
